Re: 1978 Newman 18' Pla-Ville bowrider restoration project pix and costs associated
what is the next order of business on your project?
Hi Azonic
funny you should ask because I was going to post this today anyways!
before motor came out I
wanted to run it up in the boat, but it had a siezed starter and milky oil.......the boat had at one time 2 to 3 feet of water in it....so Im HOPING it was water that came in through the outside...carb and such...and not from an internal issue CROSSING FINGERS!
well....since the cash flow issue (or lack of it) has come up recently.....
anyways the 302 v8 that came with this boat has milky oil....I decided to STOP ALL WORK on the hull and such until we get the oil pan off the engine, check the cylinders and bearings....check for block cracks (external is good so hafta look internal) and in the mean time work on prjects that dont cost much to complete etc or do honey do stuff
from there if it looks OK...we're replacing the rear main oil seal (leaking) and replacing the oil, clean the plugs, and put in the new starter....the plan calls for testing the motor on the ground (temporary eng stand) we have the harness out of the boat so well hook it all up (guages and all) hoping the oil stays clean and that it runs well....if not we have to find the problem and fix it (leak) mebbe even re ring it and replace bearings as needed etc......cheaper than a new motor!
THEN if that checks out we will replace the impeller in the stringer outdrive, reseal it and strip and paint the outdrive, new fluids etc.......
paint the hull and start re assembling by installing the engine /sterndrive / carpet and seating / etc buy and replace the bad trailer axle and hubs.......
the trailer will get paint and bunks / rollers once the boat is water ready and we can leave it overnight or 2 at the Lake Mead boat harbor ($20 per day) Kinda pricey!
then SELL SELL SELL! for spring! as we have too many boats!
this boat is our LEARN to fully repair a boat...project....we never intended on keeping it...... now we've learned that it isnt really worth it to do SOOOOOO much work on a boat you DONT intend on keeping!
We would love to keep her but really dont have the room or need as we have the SLeekcraft 23' executive about ready for the water.
