1978 Reinell 24ft Cubby Cabin Restoration
Drtrey
Just beginning the restoration of this baby. I wanted to post this up because I know I had a hard time finding info on this boat. If you have some insight on this boat or motor please post. All engine stamps were removed so I am unsure if this is a 185hp or higher.
Engine: Chevy 305
Outdrive: Mech. shift OMC 800
This boat was sitting for 20 years...yeah 20 years.
Motor started up like a champ
Issues:
Motor was seized - Added Marvel mystery oil to cylinders and sat for 5 days. Could not turn over by hand so took off belt and used starter to slowly turn over engine little by little until it unstuck.
Oil filter blowing the gasket - Stuck pressure valve in oil pump. I didn’t want to pull motor so I used Seafoam high mileage for engine oil. I put this in the dip stick, valve covers, and i mixed it with oil and poured it into the oil filter itself. After blowing the gasket 5 times it finally unstuck.
Current work:
Rebuilding the OMC 800 upper gearbox. The water pump housing cracked and the threads are all stripped.
jbcurt00
Welcome to iboats
Probably best to start a topic about motor woes/repairs over in the OMC motor forum and discuss engine work there.
Keep this topic running w details of the boat rehab.
Good luck w your project
welcome aboard.
you will most likely find rot in the transom and stringers. at that point, I would seriously look at changing to a different drive and motor than the obsolete OMC stuff.
OX5 project
Engine: Chevy 305
Issues:
Current work:
Drtrey,
Hows progress??
I am working on a sister boat to your Reinell. My project is a 24’ Cuddy. Same hull I assume but you have more cabin ...
I am removing the 72gallon fuel tank and increasing the area for engine space ....
As the other comment on dry rot is right on... check the black poly drain tubes..@ 1/2” that enter the engine bilge on each side... mine where glassed over and not open To the chime cavity it is meant to drain... once soft deck section are replaced I will add an inspection cover over uphill end of drains
Check out Reinell’s patent online to see details of hull foam I-beams in the deck..
Also old Reinell brochure is available online
Would like to talk to some old yard hand from Marysville, wa on some Reinell questions
Good luck
Steve with the OX5 Project
