1978 V5 Holiday 18, 1988 Johnson 120
budski
Going to convert to an open bow.
budski
Repaired skeg, installed complete new impeller kit and seals
Watermann
Looking forward to seeing how you guys transform this one. :encouragement:
budski
Took her out on the Red, ran good for about 5 mins, 42mph, then would not run faster than 12 mph bogs down, think its a carb problem, we installed new plugs, plug wires, compression is 120 on all four,
Watermann
Sounds like something got stopped up in the pipe works, if not check the wiring and power packs.
budski
Thanks Rob, BWR, we used a small 6 gal tank, new premium gas, we'll have to check that.as well
BWR1953
Yah. Years ago I had the same symptoms on my Bass Tracker with a 50HP Merc. Ran great then started bogging down. Then I realized that I'd not unscrewed the vent on the steel gas tank. Silly me. :rolleyes: :cool:
budski
Thanks BWR I'm pretty sure that was our problem my son told me that he also forgot to unscrew the vent on the portable tank will try it out next week, let you know how it runs thanks again.
budski
Scored a used curved windshield for my V5
budski
My son repairs props for marine dealers, we were dropping off some repaired props yesturday and I asked the owner if he by chance had any used curved windshields and he happened to have one, going to have to make the center window smaller but should work great $250.00 Canadian.
budski
Dry fitted the new windshield, fits perfect don't have to cut down the center window.
budski
Thanks guys, going to use the old windshield for my son's 1984 SS18 rebuild looks a bit better than his current windshield cause the V5 has some curve to it.
Watermann
That's a nice looking upgrade :thumb:
fetch
budski
Thanks Ron will be better when I can walk through it.
FIGMO
That was a stroke of good luck! Looks nice on there, like it belonged.
