1979 115 Chrysler wiring diagram
paul2112
Would anyone happen to have a wiring diagram for a 79 115 Chrysler outboard.? I have a manual on order but it is a week out,,Also what do these relays go to? Found a diagram over on Max Rules site, but not with these in the diagram..Thanks for everyones help
MickLovin
Re: 1979 115 Chrysler wiring diagram
Those relays look to be for the tilt trim pump, although mine doesn't have them, I am unsure if the 115hp had them, otherwise the diagram below should be what you want wiring_Chrysler_4cyl_Motorola.jpg for the rest of it.
MickLovin
Sorry I am not sure if those last diagrams are quite correct, and the one I am posting is for 1980, but it would be close to one of these two.115_140Motorola.jpg
Nordin
As Micklovin says the relyas are for the trim/tilt.
Rest of the electrical diagram as ignition, charging etc, depends on what kind of ignition system you have.
I think Maxrules has the right diagram BUT you have to find out if you have the Motorola MagnaPower I ign.system or Prestolite typ.
About in that year 1979-80 Chrysler change from Motorola to Prestolite.
