mesajeeper
Thread starter- Joined
- Jul 7, 2010
- 66
I took the pontoon boat out for the first time this season. It started up as good as it usually does (takes a few tries). It idled fine and appeared all was well. I putted out past the no wake line and began to accelerate. It accelerated fine at first but then decelerated to near idle speed even at full throttle. If I pumped the bulb, I would sometimes get a slight surge in power. We stopped for about 20 minutes. Again started and idled fine. Once I began to accelerate again, it would back down to just above an idle.
We came home and parked the boat. The next morning I proceeded to investigate. I originally thought I had a fuel pump issue. However I noticed I had a constant fuel drip out of the bottom carburetor. It appeared to be leaking from the two brass tubes at the base of the opening below the choke flap.
So I presume I need to rebuild the carbs. Can anyone provide any insight into why I have the fuel leaking? Will the normal rebuild procedure of replacing the needle and seat, cleaning all other jets and ports, ensuring the float is properly adjusted, etc. fix this leaking issue? Also, I hope this could also be the cause of the poor performance on the lake?
Thanks in advance for all the help. I truly appreciate it.
Johnson 115ML79R is the outboard in discussion.
