Re: 1979 115 temp gauge
Finished the coffee, went to garage, charged battery and went fishing in the 16' with the 1970 33 hp johnson.
Four bass and one speck later finally went to the boat ramp and headed to the house to work on the 115.
Starboard side of the heads has a temp switch, wire is broken and the other part that connects to the alarm? was inside the plastic flexable tube. Port side has no temp switch at all. The brown wire is there just tied off to the rest of the wires in the harness not connected to anything. In order for this wire to sound an alarm there should be a voltage on it correct? For example, 12vdc to a horn on the positive side, the negative side will run to the temp switch, if it gets to hot n shorts to ground the horn will sound. Am I correct in this assumption?
I grounded both wires and no alarm. Started the engine and grounded the wires again same results no alarm. I am beginning to think the temp gauge is not hooked up to anything yet when I remove the panel there is wires running to the gauge? Things that make you say "hmmmm".
I noticed my tell-tale was weak as far as pressure so I removed the fitting at the exhaust cover and there was some type of crud, looked lke old rubber hose that has sat on a ford intake for 20 years, I mean it was hard n brittle.
Maybe part of a deflector tube or hose?
Replaced fitting and connected tell-tale plumbing, started the engine and now my tell-tale stream shoots out 5 feet at idle, really strong not exagerating at all. Did I mention I got 4 bass and a speck today? *(grin).
Starboard side I believe #1 and #3 felt cool to the touch while engine was running, Port side #2 and #4 were warmer than the starboard side. I also noticed that water was coming out of the idle bypass exhaust port (openings mid way up the lower unit? perhaps incorret nomenclature) immediately when the engine started with no warm up period, bad thermostats on starboard side stuck in the open position?
I removed the hose from the Port side head to the t-stat and started the engine for a short period of time, less than a minute, water flowed freely from the port side head so no blockage on the coolant system to cause heat.
Plan of action and please if I am doing something incorrect or not required let me know.
Order two head and associated gaskets, order two temp switches, order two t-stats and associated gaskets, might as well put new waterpump on even though it seems like the one on there now is working fine. I do not know the history behind this engine but from what I am seeing little if any maintenance has been done in a long time. Thanks for the replies. WAV.
