monte100727
Thread starter- Joined
- Jun 3, 2009
- 8
i have 1979 140 without heads that I plane on rebuilding, I also have heads off a 1978 85 that i would like to use, the 85 was a 3.375 bore with 80 cc combustion chamber heads, i know these heads will bolt on to the 140 but the compression ratio may be to high, i can port the chambers to required cc if they are to small if any one knows what they should be to run on pump gas,thanks
