1979 150HP Starter Question
nguoi_viet41
have the 1979 150HP outboard only a week old i am new to boating
a lot of problem and a lot to ask event i got service manual
with a new battery full i try to start the engine
turn ON the key to start the engine the pinion turn the starter motor then crank the engine engine turn about one or 2 full turn then the pinion drop down with out tun the key off is this normal ? or what is the problem i have to look
some time i turn off the key the pinion stuck in flywheel
thanks
Joe Reeves
Re: 1979 150HP Starter Question
When the engine starts, the sudden movement of the flywheel kicks the bendix gear out of the flywheel teeth.
If the engine makes no attempt to start, the bendix gear usually stays engaged in the flywheel teeth.
If the bendix gear stays engaged while the engine is running, either the gear is jammed in the teeth or the starter solenoid is stuck resulting in keeping the electric starter engaged.
