1979 18' Starcraft SuperSport Restoration
mbroughton02
I am a bit concerned about the screw sticking up in the center at the bottom of the knee brace. I hope that was just laying there and isn't driven up through the hull.
LOL it was just sitting there. There are, however, several sheet metal screws going through the hull right below the transom. At least they used stainless? I'll have to figure out the best way to deal with those.
Got the foam out (should be able to reuse most of it) and pressure washed today.
I have a lot of glue to remove. Acetone? Other suggestions?
Question for the experts- is it worth leak testing now, or should I wait until I put a new transom in? If I do it now, the transom has so many holes I won't be able to get a whole lot of water in before it starts coming out those holes.
Watermann
I had oh I dunno about 3 gallons of glue sprayed from one end to the other on my SS, I used this...
Gorilla tape over the holes will work and you can manipulate the water level by using the trailer jack so you don't have to add as much.
Decker83
+1^^^^ I used the same on mine.. It works great.. You can also use any leftover for paint striper too..
MARUSS
The knee brace on my 78 SS looks just as bad as yours.
​Nice boat looking forward to seeing what you do with her.
mbroughton02
Got the transom out today.
All in all not a terrible job. I was able to salvage enough to where I can trace a halfway decent template for the new one.
Question: When I took the end caps off the gunwales, I still have aluminum top side material extending to over the transom:
The old transom, being in 3 pieces, was able to be removed with these intact. But do I have to take off the gunwales to put in the new transom?
jbcurt00
Yes, you need to remove just enough metal to get the new transom wood in, and still allow the cut edge to be covered by the end cap.
bigredmf
If by chance you are looking for composite transom material I have a hunk left from my 18SS transom repair and I am fairly local to you
There is more than enough to make a 1 piece transom. If you want I will post up a pic.
Red
mbroughton02
Thanks for the tip. I trimmed it today.
Red
Thanks for reaching out. The composite idea is interesting, but I had already gotten the plywood so I'm going with that.
Today I got the new transom cut out and glued up. I hope 720 lbs. of steel will keep it together until the glue dries :)
Candutch
Great progress. Your boat doesn't look any worse off than most of the restores on here. The knee brace is an easy fix with some aluminum angle and ss screws or solid rivets, I went with ss screws and 1/8" angle.
Looking forward to watching you progress.
Decker83
If that doesn't work, I guess you could drive your tow rig on it..:lol:
Great looking work your doing..
mbroughton02
Transom is in the process of getting several coats of spar varnish. A few random questions:
Is this from an old bimimi?
And what are these?
Watermann
Yeah those are slides on the gunnels for a bimini. Those other things are junk that has holes for you to repair. :lol:
mbroughton02
That's what I suspected. Thanks.
Also, these buttons are obviously from a cover:
Is it worth keeping them on and stripping / painting around them, so that I can reuse them for a new cover when the time comes, or should I take them off, patch the holes, and install new ones when I get to that point? Opinions?
Watermann
They should just screw out and can be removed with a phillips screw driver. If you plan on doing a snap on cover then leave the holes and keep them if they're stainless snaps but I would replace them if they're looking the least bit ugly.
FrankenCub
Those rectangular brackets were probably for wood bows that kept an arch in the mooring cover. Seen those a lot when I worked in a marine upholstery shop.
PikeHunter431
To add to FrankenCub's comment, the rectangular brackets are for bows for holding covers up. The come in wood or fiberglass. They look like long slats and should be a bit longer than the length between the brackets. Thus when you put them in, they arc up into a bow. Some people use them on mooring covers or travel covers. They normally are not strong enough for much of a snow load. One problem with them is they can rotate and thus fall out of the bracket. Some people will tie a rope from one to the other and the ends to the boat bow and stern, tying them at the top of the arc so they don't do that. Sometimes people rig up a strip with snaps on them.
mbroughton02
I see. Sounds like kind of a hassle. With our 15' boat I just use these posts to keep the cover up:
But still not any good for a snow load. We keep it in a small garage at my girlfriend's mother's house in the winter.
Speaking of the 15 footer, since I know you guys like old tin, this is our functional boat as opposed to the project boat:
It's a 1988 Smoker Craft with an evinrude 28 SPL, same year. Owned by my girlfriend's father since new, and always kept in a garage. It's simple yet almost pristine. He handed it down to her last year and I redid a bit of wiring that mice got to, rebuilt the carb, changed the oil in the lower unit, new impeller, new spark plugs, and had to replace the stator or some other electrical thing under the flywheel. Took it out today for the first time of the season and the motor started as if it was running an hour before. I should have been putting the next coat of spar on my transom, but the weather was too nice to resist:
I promise I'm not the kind of guy who puts his dog in every pic, but it just so happened that the first pic is the only one I have of the Smoker Craft without the cover on.
Watermann
Yeah I like pooch pics too and Smoker Craft is made by Starcraft so I'm all in!
Watermann
Yeap as is Sylvan, Northwood and Starweld. I feel like I'm missing one too. Anyway there's a couple smoker rebuilds here in the SC section being worked on and a Syvan, the 80's models smoker and sylvan are identical to the SC SS right down to the last rivet.
