- Joined
- Oct 25, 2011
- 25,110
Re: 1979 22' Starcraft SuperSport V5 Restoration
Will the hammer smack loosen the rivet from the stringer enough to allow the existing rivet to be thru punched? If it's loose, it'll like end up in the bilge anyway after you drill the head off.... Then you might go 1/32-1/16" bigger rivet (but maybe not?) & use the existing deck & stringer holes..... Probably want to make a little bit deeper countersink though, leave you enough room to fill w/ epoxy & sand smooth as suggested.
