spacemonkey77
Thread starter- Joined
- Nov 16, 2015
- 62
Hey guys. You all helped me a few weeks ago with some seal replacement work and what I thought was a knocking noise! I got everything back together and it ran great at first but has now developed this running issue. See the video. I’m not sure if it’s a fuel issue, or an electrical issue. Perhaps timing and linkage issues?
any ideas where I should start?
Compression is good. 120 both cylinders! I checked all my grounds and they are good. Fuel pump test showed no leaks out the hole! Power pack and coil packs are about 2 yrs old! I used a timing light on the plug wires and both cylinders seem to be firing fine! Plugs are a little wet. I rebuilt the carb probably six months ago and have used the boat regularly. Only ethanol free at 50:1
