beretta5spd
- Joined
- May 12, 2010
- 17
Hi all,
The story is last year a friend sunk my boat. I pulled the boat out of the water, pulled the plugs, and turned it over to push out the water. Reinstalled plugs and fired it up at idle for 10 minutes. Ran good.
Fast forward through a ridiculously cold winter (boat was stored indoors) and now I only have spark on 2,4,6. I hear that the most likely problem is the stator through my research but you all are the experts!
I hear that you can exchange wires on the switch boxes in order to check if it's the stator that's causing the issue. Attached is an image of the electronic ignition, if you could point me in the right direction in order how to do that it would be appreciated. If I am barking up the wrong tree please point me in the right direction. Any help would be appreciated.
Dwight
Dwight
