We seem to be having problems keeping the motor running. Sometimes it will start right up and work fine then later it cranks but won't start. Carbs rebuilt (2) Also had problems of putting it in forward gear it would die but oddly enough it would do fine in reverse. Seems like hit or miss, intermittent. Gapless plugs don't appear to be flooded. Understand that at about 30% throttle is when the carb cam moves. We're not comfortably sure of control cable adjustments as we bought the controler separate from the motor and just hooked them up.
Some questions for starters. We believe we are correct that it uses a vented gas tank and it is vented. We pulled the line from the tank to the fuel pump and primed the bulb and it works, then checked outlet form fuel pump to carbs and it pumps good. We set the float in the carb according to specs with rebuild kit whis says 1/2 in full and 7/8 empty.
Starter sometimes does not engage fully and spins freely and understant this minor problem is unrelated to running problems naturally. So we'd like also to find a starter for this motor and have found the site Sea Way Marine has a supply of parts according to their site. Are there any other sites out there where we could find rebuilt or new starters, doubtful for new.
Thanks
Thanks
