Runs on all three. good compressionCarb problem or suddenly running on all 3 cylinder from ignition problem. Need to investigate before running any more as if carb problm you have a cylinder not getting fuel and oil.
Compression test first the check ignition
Thank you will test this when able too. Looks like spring.It is not running on all 3 when its acting up...when it jumps to full throttle is when all 3 are working. Need to test ignition and fuel system
