jjacobs007
Thread starter- Joined
- Mar 10, 2009
- 1,257
hello people thanks for reading! took out my new 2 me motor it started up perfect idles the same,goes 2 wake speed then theres nothing if i go any further with the throttle,it just dies,half to pull back quickly to keep her running.what do you advise i do in what order to fix the problem.runs perfect other than that.I noticed the advance lever under the flywheel for the ignition only moves until it hits that stopper.mine seems really like it might be holding it from going where it should.like it moves only 2 inches or so before hitting it.the screw is almost all the way out toward the lever.dont know if this is a problem thanks 4 everything peolple.
