1979 - 75HP 2 stoke gear issue?
Calibra
Hi
Someone I know has a 1979 75hp 2 stoke Evinrude
Engine fires over fine. When you put it in to forward gear, the engine stops dead.
What is a common cause of this? Gear coggs screwed?
Thanks
James
In nuetral the gears are all spinning !-------Perhaps the motor is not developing enuff power to turn the prop.--------Check compression and check for spark on all 3 cylinders.
