1979 85 hp evinrude gas to oil ratio?
Jim d
What is the gas to oil ratio for a 1979 85 hp evinrude outbard boat motor?:confused:
Jim d
Re: 1979 85 hp evinrude gas to oil ratio?
Thank you. The person I got the boat from said 40 to 1. I am a little virgin to boating. What is tcw-3?
Vic.S
TCW3 is the current spec for a two stroke outboard engine oil. TC = two cycle W= water cooled. 3 is the current spec, the previous one was 2.
Would not hurt to run 40:1 but not necessary
50:1 is near enough 1 pint in 6 gallons
20ml per litre if you are where litres are used. (The rest of the world outside the USA)
Jim d
Thank you. I will get a manual.:cool:
