I have this motor here with no spark on bottom cylinder. I swapped the wires from the CDI box to the coils and the problem moved with the wires, top cylinder quit, bottom had spark. Stator and trigger wires OHM'd within CDI electronics recommendations DVA voltage for Brown/Yellow, Yellow /Brown wires were OK, Black/White to White/Black were high at 2.5 volts, supposed to be .6. I figured the trigger was bad and pulled the flywheel off, guess what? I can't find a trigger.
I looked at the parts diagram and it shows one, but there is none under the flywheel. The parts diagram looks like there is a gap on the stator where the trigger would fit, but the stator on the engine has no gap. Is the trigger built in to this stator?
