Re: 1979 Evinrude 200 hp v6 fuel economy
Yes on the aquasport.
Sadly, I can't give you the information you're looking for... I still havent redone the instrumentation, I was running alongside a buddies boat, and we turning around 35mph, and rough guestimate would be about 4500rpm when I got it optimized. Running that, I was able to get the 10gal/hour, full tank, plus little over half another.(had 3 tanks with me, 2x6gal, 1x12gal).
The worst economy was wide open which got me 42-45mph, and at WOT (5500ish), it killed the 12gal tank in about 45mins.
Hope the info helps! When I get the gauges all finished (hopefully this weekend), I will run some more tests.
Now we are getting a closer comparison. I assume you are running that engine on your Aquasport; even though the boat is smaller than mine, the hull lines look similar. Can you tell me what engine RPM and boat speed achieved the 10 gal/hr? I guess in a couple of months when it warms up here, any surprises I have on fuel consumption will be good ones..........................Don
