1979 Evinrude 70 Top End Issue Under Load
ram1969
I have a 1979 Evinrude 70hp that seems to be starving for gas at high end under load.<br />When I run the engine out of water, it idles fine, runs fine in forward at all levels and reverse as well.<br />When I put the boat in the water under load, it seems to loose power and only runs well at the slow speed. As soon as I engage into high speed, I have to keep priming to keeep it running.<br />I bought a new gas line from the tank to the engine, new spark pugs, blew out the lines with compressed air and checked the fuel filter.<br />Any ideas?<br />Thanks
Reel Appeal
Re: 1979 Evinrude 70 Top End Issue Under Load
Check the vent on the fuel tank,make sure its open or not clogged(if permanent tank).Look for clogged pickup tube/screen in portable tank.Check all fuel line connections for leaks and tightness.Check the fuel pump screen(filter).Malfunctioning fuel pump.Carbs may have dirt/debris blocking the jets.
