1979 Evinrude 70973R 70 hp Outboard
rodpaulrod
Anyone will Evinrude Johnson OMC Outboard 55 60 HP Cylinder Head 313412 313415 fit my engine i see picture and this one look just about like my head off my engine
KJM
Looks like you are running that motor without water? You will need a new impellor, but thats the least of you problems right now! Did you try a big hammer and wood like suggested? That head is ruined now anyway.
rodpaulrod
that head not come off that way.
and it off not but not that way.
not do know if Evinrude Johnson OMC Outboard 55 60 HP Cylinder Head 313412 313415 will fit my engine i see picture and this one look just about like my head off my engine accept for side where you would screw the ignition coil into
rodpaulrod
drilled out and cut with grinder tried a puller and acetylene torch it was welded in with corrosion and one bolt broke again Basically had to cut and drill around the bolts get it off and got my heli coil in there now . but have not went past that part yet, the water was just going from on cylinder to others cylinder you could see the path (trail ) on the old head gasket left by corrosion color like dust sand. Hey how did it even run and sometimes ran real fast . Huston we a new power source you utilize and you figure it out.
rodpaulrod
I can not see , feel or hear your motor.----Up to you to post some information.---Post compression test values.----Does spark jump a gap of 3/8" ( 1 cm ) on a test device.-----Does manual fuel pump go hard when operating it ?
i got engine back together and ran it and was not pumping water took lower off and it looks like it sheared the impeller key did not see a key in there so got try get a key and how about that gasket in the picture what will that cause can i use it like that or Will this give water a chance to get into the cylinder if that gasket is bad.
tphoyt
Get your self a complete water pump kit and a new exhaust housing gasket if you plan to move forward with the project.
rodpaulrod
okay is the key looks like a circular segment or like a Psychographic Segmentation i think try to make for just this weekend anyone have ideas of size?
Honorary Supreme Mariner
The key should be there somewhere,----Look under the bottom plate of the pump.
rodpaulrod
yea it sheared the key and i made a new key and but sealant on exhaust gasket put back together once the neighbors wake some i start it
