ChristianMariner
Thread starter- Joined
- Jul 1, 2013
- 131
Hello All,
I purchased a used boat and insisted that the PO would take it on the water to show that it was in working order. It is an open bow trihull 16 ft Newman Cam II with an Evinrude 85 hp motor.
We took it out for about 20 minutes. It started ok, had to try it 3 times before she fired, and then it warmed up and we took it out. Went for about 8 minutes through the 5 mph zone then out to the open water, got it up on a plane, no problem. She ran beautifully. Came back through the 5mph / no wake area smoothly and I bought her.
Now, my first trip after buying her, I was plagued with motor problems. First, took forever to start. Very unlike the previous experience. Then, once running had a bad miss at low spees going through the 5mph zone. Once out in the open water, the boat smoothed out a little after giving some gas. Then wouldnt go above 2k rpms. Runs very smooth at WOT but wouldnt go above 2k rpms. Then, every once in a while, would just start trying to, and then would bounce between 2k and 2.5k and then sometimes would hit 3k. Then would fall back to 2k. It really is jerky when doing this... Crusing at wide open throttle and starts jerking forward as the rpms jump and fall off. I thought maybe I had fouled the plugs by starting it incorrectly and choking to much. I changed the plugs and she started way faster and smotther, but ran the same way on the water. Nothing over 2k, and then sometimes the jerking and missing up around 2.8k then back to 2k.
Next, I changed the fuel line from the tank to the motor, and removed the squeeze bulb and put in an electric fuel pump there instead. After about 15 minutes of the exact same bad behavior, the RPMS wouls go up to 2.5k consistently and after an hour like this I could get up to about 3.5k to 4k at wide open throttle. Sometimes really smooth, sometimes doing the same jerking and hesitating near the 4k mark.
So, I took it out again with the same setup, hoping it would eventually get better. It did not. It is still starting ok, going smooth at low RPMs through the no wake zone, and accelerating nicely upbto about 3k but then it sometimes stays there and sometimes bounces its way to 4k and sometimes not.
I am a total newbie and am hoping this kind of behavior is something that points to a common problem that I am just unaware of. I have scoured the net and also the OMC sticky page of this forum, but havent seen anything that sounds like my situation. Thanks for reading and hopefully someone know what would cause this.
