1979 Evinrude 85 hp Model # 85999c $800 is this high or low?
SilverSS07
Re: 1979 Evinrude 85 hp Model # 85999c $800 is this high or low?
Yes, figured compression test would be good idea, just put my compression tester in truck tool bx.
Hadn't considered impellers but will replace them for sure, makes sense, spend a little now, save a lot later!!
Any other parts besides plugs I should also consider just replacing once I but it?[/QUOTE
I would check the wiring and all the fuel hoses. Mine were all hard and brittle so I replaced them. Once the motor is running check that the thermostats are working. I found out someone had removed them on the engine I bought. Change the lower unit oil when you do the impeller. Grease the zerks for the tilt and mid section. I rebuilt the carbs and fuel pump also but that was just for peace of mind. I knew the engine Sat for a while before I bought it.
Honorary Supreme Mariner
It almost appears that head gasket on port side is installed wrong.
