duckboat5112
Thread starter- Joined
- Jun 2, 2009
- 4
Frist off hi everyone ok now on to my question i just recently purcased this motor i replace all the seals in the lower unit and now impeller i put it all back together and noticed a gas leak in the filter cap when i pumped the bulb so i went and replaced the cap and it still leak we exopy the leak for the time ( i am going to get a new cap and rebuild kit this weekend) well anyway we put the muffs on it and it would crank up and run good so we took it to the river and it cranked but when you would put in gear it would go about 5 sec then die so we mixed up some fuel/oil mix in a sspray bottle and it would run as long as you were spraying it is it my carb or is it maybe a oxgyen problem thaanks guys
