1979checkmate
Thread starter- Joined
- Jan 15, 2011
- 261
Hello Fellow boaters,
I have a 1979 mercury inline 6 115 hp, (on a 1979 Checkmate Trimate-II.) I just finished replacing the stator, trigger, one switchbox, rebuilt carbs, rebuilt fuel pump (new diaphram). When i got the motor put back together, she fired right up, But had a Very high Idle (i am not sure how many rpm, as i do not have a tach on my test stand, but she was reving high) Last summer, i did adjust the idle stop screw to give a higher idle to the motor(this is before i replaced everything). But now that the motor has all of these new parts, it is overreving. So, i turned the idle stop screw back down to get the motor to a decent idle, which it did go down. However, the idle timing arrow is no longer aligned with the line on the throttle, it is just a little bit past. My question is, will i hurt anything by running it like this with slightly retarded timing in order to keep the idle revs down?
