TampaBoater
- Joined
- Feb 23, 2012
- 207
I have a 1979 Johnson 115 sea horse with no spark on top port cyl. I have replaced stator, timer base, and have ruled out power pack issue. Rectifier seems to be alright I get readings one way but not the other. I figure its got to be a coil. Its the kind that comes with the spark plug lead all built in. Other than replacing the coil, can I do something to test it besides swapping it with the bottom coil? I don't want to do that because I would have to re order the connector pins. Can I test it for ohms? Would I even get a reading? I have already taken he coil off the motor? How should I connect the test leads on the multimeter?
Any help greatly appreciated.
