Re: 1979 Johnson 150 "kick"
Did you ever try using an inductive timing light to check spark? When running in gear on the lake, have a friend steer, while you remove the cowl. Put the timing light on each wire and note the flashes from the gun. They should be sharp, rhythmic on all 6. Weak firing and misfires should show up in the gun.... If you find one plug or one head that has firing issues: that engine has 6 common coil plugs and two power packs, any of which can be swapped for testing purposes. If the spark is erratic, it could be a bad stator.
