NorcalChrisCraft
Thread starter- Joined
- Jun 13, 2009
- 65
Hi, hoping to get some input on a problem I am having with my outboard.
I am pretty sure it is a 1979, it's a johnson 15hp 2 stroke. It seemed to run fine out of the water but once in the water wouldn't get me on plane. Tore into the motor and found I have no spark on one of the cylinders. I swapped the input wires to the coils and the problem follows the wire so I know it isn't the coils, plug wires or plugs.
I pulled the flywheel to see if the keyway had sheared and the timing was off but everything looks fine. There was also no corrosion under the flywheel so I cleaned everything up and reinstalled and still have the same problem.
Anyone have ideas on what I need to replace? Tying not to throw money at it blindly. Thanks!
