Re: 1979 Johnson 4hp Water Pump
Hi Dave<br />The water pump empeller on an outboard is a annual service item. Most will run longer. The trouble is varing conditions. I don't think anybody knows for sure how long. Sometimes the rubber vanes will degrade and block up the cooling system. Quite often the hub of thhe empeller will delaminate from the rubber. In this case the empeller will look fine. The trouble is the hub spins inside the rubber and doesn't pump. As these parts are relatively inexpence compared to the possible damage that can occur, they are hardly worth taking a chance on. The L/U should be removed and the driveshaft splines,propshaft lubed and gear oil changed at least annually any way.
