Dabbler_E
Thread starter- Joined
- Apr 20, 2009
- 338
This thread is partly to solicit input, and partly to record what I find out for others.
**UPDATE:
**HERE'S A SYNOPSIS OF RESULTS SO FAR:
**Intermittent spark on one cylinder
**Which cylinder has a problem varies over time (not always the same cyl)
**Appears to show up most when timing is advanced
**Sensor coil and ignition coils both show resistance within specs
**Problem comes and goes
**The fact that it only applies to one cylinder, and which that it moves from **cylinder to cylinder seems to narrow it down to the sensor coils (timer **base), but the resistance test came out OK. I don't have the special tool **to do a sensor coil output. It seems to me that the only other possibility **is the power pack. Could that cause these symptoms? I would expect a **power pack problem to affect all cylinders.
**END UPDATE *****
I have a 1979 Johnson 70 hp that cold-starts great, idles fine, and runs up to WOT no problem. However, on a couple recent occasions it has died (slowed down then stalled) after high speed runs (4500-5000 rpm) lasting for 15 minutes or so. Last night it happened while we were getting out of the way of a popup thunderstorm, and fortunately it decided to die in sight of the dock.
In both cases, it was running fine, then started slowing and stalled within about 10 sec, once the boat came off plane. Could be restarted with difficulty, but it only kept running if spark was advanced. In the first instance, I was able to get it back running in gear (very slowly) by quickly dropping the starting lever and pushing the throttle to advance spark. Last, night, I was not able to even get that.
At first, I thought the fuel gauge was faulty and we were out of gas, but no, there was plenty of gas and the primer bulb was hard. All 3 plugs wet but not fouled. After we got home (motor cold), I was able to start and run it on muffs with no problem.
My thinking at this point is a flaky charge coil, but I aim to take the boat out today and see if I can replicate the condition and do a spark test.
**UPDATE:
**END UPDATE *****
