1979 Johnson 70 Prop shaft seal replacement
Dabbler_E
Gear oil was milky so I pressure tested the LU and found air and oil leaking out around prop shaft. I have the seals (and the OMC flywheel puller and manual) and am about to go ahead with replacing them (along with the bearing carrier O-ring and the water pump while I'm at it), but just wanted to get any tips or "while you're in there"s from the collective wisdom here. Thanks!
Dabbler_E
Vic.S
Re: 1979 Johnson 70 Prop shaft seal replacement
"While you are in there" you might as well do the drive-shaft seals and the shift-rod seal as well perhaps.
