1979 Johnson 85HP tachometer
healey8390
Trying to find a tach for my 1979 85HP Johnson. I was told I need one with the right poles? One site says 6 poles so I just want to confirm here, thank you.
Joe Reeves
Re: 1979 Johnson 85HP tachometer
That would be a tachometer that operates off of a 6 pulse alternator (yours). It would have a numbered dial on the back of it which you would set to number 6.
It normally has four wires leading from it:
Red = To 12v source
Blue = To light switch
Black = To ground
Gray = To sensor
F_R
A bit of terminology here. It has 12 POLES, which produce 6 PULSES. But you are on the right track. Just think 6 and you will be ok.
V153
Ya if'n it's an OMC tach the correct dial setting would be 6 pulses (12 pole stator). Personally I'd shop around & find a decent period correct OEM tach vs buying new. They seem to work better?
