Maddoxsdaddy
Thread starter- Joined
- Sep 22, 2008
- 222
It had a 15P stainless prop that had been on it for apparently many year as i had to burn the rubber out of the hub to get it off. I'm replacing the prop with a 12P so the motor will get into the correct RPM range. The 12P prop i have came off of a 1988 60hp 3cyl. Merc. The splines are the same between the 2 motors but the hub #'s are different. I put the 12P on and it would not go up onto the shaft as far as the old 15P. It looks like there is a spacer of some sort on the prop shaft about 1/4" thick... the amount that the 12P won't go on. Will it hurt anything to take the spacer off the shaft or should i change the hub in the 12P to match what was on the 15P???
Thanks....
Thanks....
