Maddoxsdaddy
Thread starter- Joined
- Sep 22, 2008
- 222
Ok... here's whats been done to this thing... New stator (all ohm's check ok), rebuilt fuel pump, new fuel lines, rebuilt carb and cleaned multiple times. The only thing in the fuel system that hasn't been rebuilt/replaced is the fitting where the fuel line comes into the motor that attaches to the hose fitting from the tank. Nothing has changed since i first started this "project". I still only get 15 mph out of it on a 17' Alumacraft. It has a 15P prop on it now, getting ready to drop to a 12P to see if RPM's come up. I don't have a tach yet but will have one hooked up by next weekend so i can't tell you what RPM's it's running. It just seems like this motor should be doing quite a bit more. It starts fine, runs pretty smooth... just craps out and has no top end. Any help or suggestions? I also have a new fuel tank, external line, bulb, and new gas.
