zanderman111
- Joined
- Mar 15, 2009
- 28
I recently purchased a 16 foot Glasspar boat with a 1979 90hp Merc 6cyl. The boat came with two batteries, I was told they were good. Put ear muffs on the Merc and turned the key. The starter cranked really slow and weak for about 2 seconds, then took off like crazy (though it took the engine several seconds to turn over). Once running, it ran great. I was suspicious of the batteries being weak, but put a volt meter on them and they were reading ~13 volts so I thought nothing more of it. Took it out to the lake and put it in the water, and tried starting it. Again I got a very weak crank out of the starter, only this time it was not enough to kick the engine over, just cranked very slowly. Very disappointed, I went home and had the batteries tested at Wal-Mart. They said both of them were shot. I bought a new battery (750cca) and hooked everything up to just the one battery (which should be plenty), and tried starting it again with the earmuffs. Again, I got the same slow crank initially for about 2 seconds, then the starter took off like a scared rabbit and the engine fired up about 5 seconds later. Now I was suspicious that it wasn't just the battery. I started it several times in the driveway with the hose and the slow initial crank, so I thought that was maybe just how it was. Took it back to the lake, turned the key, got the slow initial crank, then cranked normally for a few seconds until I let off the key. I turned the key a second time and got just a click. Absolutely nothing more. Voltage on the battery was fine, and the hydraulic pump for the tilt worked normally, but no crank, just a click. Now im thinking its the starter. Any thoughts? I took the starter off and during the disassembly, I noticed that the gears on the starter were engaged with the gears of the flywheel or crank, whichever its called. Are they supposed to be permanently engaged like this? Or are they supposed to disengage after starting? Any and all information/help is appreciated! Thanks
