Hello,
This is my first post but I've certainly benefited from all the knowledge gathered here on the forum. Thank you!
I have a 1979 Mercruiser 260
Chevy 350 with a MR1 outdrive.
Raw water cooling. No heat exchanger.
The boat is new to me.
It starts and runs strong but I've been chasing my tail for a while with an over heating issue.
-It immediately started to over heat.
-I checked the impeller in the outdrive and it was melted down.
-I replaced it with a new impeller, top and bottom housing and cleaned all debris from the outdrive.
-It over heated again.
-I checked the thermostat and it was rusted - replaced with a new marine thermostat.
-It over heated again. This time the starboard manifold cracked. :grumpy:
-I pulled off all the cooling hoses, manifold and riser. I checked for blockage - nothing substantial.
-I drilled out the cracks and jb welded the manifold and bolted it back up (a temporary fix) to continue testing the system.
-It over heated again so I finally decided to check incoming water flow - I know i'm a little slow.
-No water flow into the boat.:facepalm:
-Pulled the outdrive and the impeller was melted down again.
Any thoughts on what could be causing this problem? Like i said i replaced the entire housing, impeller and gaskets the first time. The key was properly inserted and fully engaged on the shaft.
I did notice that the new impeller was very tight. I had to put a wrench on the shaft to turn it once it was in the housing. Also, I torqued the impeller housing bolts to spec and the gaskets didn't seat so i torqued it beyond specs to get contact and then backed it off to specs. It seemed to be seated and sealed but i'm wondering if that indicates that I did something wrong or maybe got the wrong impeller?
Any help or suggestions will be very appreciated. Thanks before hand.
