1979 mercury shifts backwards after impeller replacement
notyepcars
I have a 1979 mercury 50hp 4 cylinder 2 stroke that is shifting backwards after replacing impeller. I had a hell of a time getting the lower unit back in without shifter binding at the console. Thought I had it, but put it in the lake today and it is shifting backwards. Push forward on control, and it goes into reverse and visa-versa. What did I do wrong?? Thanks
Chris1956
Honorary Supreme Mariner
That is a common problem. The cure is to remove the gearcase, turn the shifter CCW until it clicks into neutral, set the control to neutral and reinstall the gearcase.
notyepcars
Ok, I’m assuming I need to turn that ccw with a vice grip as it doesn’t turn easy. Also, there is a plastic/rubber piece that goes over that same splined shifter rod that has a notch in it, what direction does that go? Thanks
