1979 Sea Ox repower question
mattmjm90
I've got a 1979 19' Sea Ox center console. The USCG plate says the max horse power is only 90hp. Why is it so low. I have a 6cyl 90hp on it now but just recently came across a great deal on a 200 hp 6cyl johnson but had to turn it down due to the rating plate. It seems like it would be a bad idea to go against the rating and I do realize the 200hp was way over that thats why i didn't get it. I just wanted to know if it is possible to go over the recommended rating, and how far over.
tashasdaddy
Re: 1979 Sea Ox repower question
it's possible, your transom might fall off, you hull may break up, and in most states it is illegal.
The United States Coast Guard has an opinion on this frequently asked question, and their answer from their website is reproduced below:
Can I use a bigger motor on my boat than what it's rated for?
It is not a violation of Coast Guard regulations to install or use an engine larger than specified on the capacity label, but there may be state regulations prohibiting it, and restrictions from your own insurance company regarding this.
There are no Coast Guard regulations against exceeding the safe loading capacity, however, there may be State regulations or restrictions from your insurance company which prohibit this. There is a Coast Guard regulation that gives Coast Guard Boarding Officers the power to terminate the use of a boat (send it back to shore) if, in the judgment of the Boarding Officer, the boat is overloaded. There is no fine for this, unless the operator refuses the Boarding Officer's order. We certainly hope that you will abide by the rating, as overloading may lead to capsizing or swamping of the boat.
NOTE: The Coast Guard Capacity Information label is required only on monohull boats less than 20' in length. The label is not required on multi-hull boats, pontoon boats (catamarans), or on any sailboats, canoes, kayaks, or inflatable boats, regardless of length.
As the Coast Guard mentions, local regulations may apply. For example, in the state of Ohio one should be guided by this regulation:
Capacity Plates
(ORC 1547.39 & ORC 1547-40)
No person shall operate or permit operation of a watercraft in excess of any of the stated limits on the capacity plate. When no capacity plate exists, no person shall operate or permit operation of a watercraft if a reasonably prudent person would believe the total load aboard or the total horsepower of any motor or engine presents a risk of physical harm to persons or property.
chiefalen
You sure it's not a 3-4 cyl 90 hp motor ?
My friends boat has a i/o with the plate stating 130 hp max. He has a 3.0, 135 hp.
And thats my recommendation don't go over 10 hp the max on the plate.
Just my 2 cents.
