Moserkr
Chief Officer + Starmada Splash Of The Year 2021
- Joined
- Nov 23, 2020
- 883
Lunch live update! Got the front deck fitted but ran short of rivets! Luckily i foresaw this coming, and ordered some to be here on monday. Hoping 100 is enough lol, cause that would be +\- 300 LF blinds for the complete deck/gunnels. Will install the casting deck as soon as those rivets get here, but its ready.
Under the casting deck, on the main deck, i put a coat of spar over the epoxy, which will all be covered by black neoprene (spars drying now). Protects the floor of the storage area and is going to prevent stuff from going down into the bilge - except water of course. I will put a coat of spar across the whole main deck before the actual floors go in.
Moved on to the gas tank which was surprisingly easy, and not surprisingly very tight fitting. Barely made it with the 1.5” fill line - there is no room for error between it and the floor. I cut through the console and it will route along the inside up to the gunnel. But it fits!! Can finish that up as soon as the casting decks in and my vent line comes in. So...
This afternoon, its consoles and electronics time! Hoping to get a good bit done but we shall see. I need the basics - auto bilge and motor hardwired to one battery with a kill switch. Safety lights to a fuse panel on the auxiliary battery, which will also power the fish finder, radio, manual bilge, and other electronics eventually.
Back to work!!
Back to work!!
