1979 Starcraft 18 v5 Restoration re model
shark1600
Re: 1979 Starcraft 18 v5 Restoration re model
Looks great, good job, missed this rebuild.
budski
Built a new gauge pod smaller than the one I was going to use, gives me more room on the console for a fishfinder and I'm only going to need 4 gauges anyway IMG_7468.jpgIMG_7471.jpgIMG_7475.jpgIMG_7479.jpg IMG_7481.jpg
dozerII
Real nice job John, what did you use for the front edge of the aluminum top?
budski
Thanks Glen, how you feeling, good I hope, actually I wrapped the whole top shell with 1/8 foam glued on, the same foam they use for laminate flooring, then glued and wrapped the vinyl over it that gave the front edge a little thickness, also the rivets hardly show on the top.
jasoutside
John, whatcha gonna use to strain your spaghetti now???:rolleyes:
Bah, messin with ya, looks awesome, factory!:thumb:
budski
Thanks Jason guess I'll have to worry about that next time I make spaghetti actually the reason I used that aluminum is it was a fairly thin gauge and easy to form.
GA_Boater
Now that looks good! In fact it looks store bought. Nice job. :thumb: I'll withhold eyebrow comments since some of our Northern neighbors were offended the last time. But I do like "sunshield" over the arc above the gauges.
budski
crankbait cowboy
real nice bud. what did you use on the face ( what material is that, vinyl , fiber board? ) looks real sharp. and i like the decal
budski
Thanks CB, it's carbon fiber film stick on same thing that Dozer used on his dash pretty good stuff I've used it before with good results. it comes in different colors walmart carries it here in Canada
crankbait cowboy
thanks, looks real sharp, gonna look into it , i assume it has a pretty good adhesive?
budski
Got the hull sanded primed with black self etch primer and the first coat of paint on, going to let it dry overnight and tilt on other side and finish bottom and do 2nd coat tomorrow
Watermann
Paint looks great Bud! Too bad the forum is so porked still.
budski
Thanks water, going to get some decals on tomorrow weather permitting
