Re: My quest to find a cheap 1970's Starcraft SS!
the lower transom does look different
I use one size smaller drill bit to the rivet fill
how about these ideas
some sort of internal splashguard made of aluminum, and/or, starboard material
since some marina guy did the transom on mine before I purchased, I just sealed it under the splashwell with Gluvit since no UV in there
If I was building a new 1.5" transom, I would take 2 pieces of 1/2" plywood cut to "cross-lam/grain" each other for 1", then sandwich the epoxied wood between two pieces of 1/4" starboard material
This would provide strength as well as the outside and inside virtually waterproof
I would also bring in my favorite NASHUA waterproof butyl tape into play to seal all the outer edges of the transom before installation and capping. jas, how would one attach that angled piece if added?
