1979 Supersport 18 V5 Rebuild
budski
IMG_5335.jpgIMG_5336.jpgIMG_5370.jpgIMG_5489.jpgIMG_5342.jpg 79 V5, 2001 Merc 125 2 stroke oil injected.
budski
Re: 1979 Supersport 18 V5 Rebuild
Starting the tear down IMG_5930.jpgIMG_5931.jpgIMG_5932.jpgIMG_5933.jpgIMG_5936.jpg
budski
Got the trailers switched from my keeper, to my gonna flip rebuild. IMG_5942.jpgIMG_5943.jpg
budski
Built another gauge cluster same as first one going to use it on this rebuild. IMG_5927.jpgIMG_5926.jpgIMG_5929.jpg
glnbnz
Looking forward to your progress.
jbcurt00
Gauge cluster looks great! So does the new flip rig!
budski
Thanks Glen, JB, a little more progress on the tear down, looks like someone else did some tearing of their own before me. IMG_5947.jpgIMG_5945.jpgIMG_5951.jpgIMG_5960.jpgIMG_5961.jpg
duncan_the_red
Looks almost like someone was trying to access where the fuel lines go through the stringer into the tank.
budski
Actually no it was on the drivers side, can se where they replaced a couple of rivets
budski
Got the inside gutted except the floor, I cut the councils off with jig saw, going to reattach later with aluminum angle a lot easier redoing the floor when they are out of the way, also easier to carpet them when not attached, found out the hard way that wasps can sting more than once was removing padding in the bow reached under the gunnel to remove a screw and felt something went to remove it and ouccccccccccccch got stung about 4 times that hurt but at least I got rid of the nest stomped it must have stood on it about 5 minutes, didn't have any insect killer so sprayed the heck out of under the gunnels with room freshener, think it worked. IMG_5975.jpgIMG_5976.jpgIMG_5974.jpgIMG_5969.jpgIMG_5972.jpg
budski
Going to have to move my windshield forward about 2 inches to acomidate my new gauge cluster, there's room may have a bit of a problem re aligining it but should be no problem.
pckeen
Fast work - look forward to following along. How hard was it to get the side panels off?
budski
Thanks pc the side panels are actually easy just a few screws, but some boats use rivits then you have to drill them out.
budski
Floors out, think I displaced a few little critters, tomorrow take out gas tank clean and inspect and repair rivets if nessecary. IMG_5978.jpgIMG_5979.jpgIMG_5980.jpgIMG_5981.jpgIMG_5982.jpg
duncan_the_red
Thank goodness it wasnt poured in place foam ! Looks great. How did you get the carpet out ?
dozerII
Holy cow John you don't waste any time, I took a week off to go fishing and come back to the forum and your half finished another rebuild.lol
budski
Hey Glen did you catch any fish, not really close to being half done, the easy part's done my son is away for about a week, when he comes back we want to flip it over sand it down and paint it, going to be a little harder than the sylvan. how's the mercruiser running. Duncan you just have to use brute force to get the carpet out, this one was a little harder than the others I've done they used a lot of glue, but that parts done.
budski
Got the gas tank out, looks a little different than yours Duncan, mines completely square and has a aluminum enclosure pop riveted in place and what looks like a very water logged and rotten 2x4 support under it, I guess I'll have to remove the aluminum and replace the 2x4 support wish mine was like yours Duncan would be a lot easier. IMG_5983.jpgIMG_5985.jpgIMG_5986.jpgIMG_5987.jpgIMG_5989.jpg
duncan_the_red
Looks like you have an aluminum bottom tub riveted in between the stringers under your tank. My support plywood rested on the hull supports with small pieces of foam underneath. What capacity is that tank ?
budski
Yes thats exactly how it's built except it has what looks like a 2x4 support under it, going to be removing the aluminum tub soon so I'll know for sure. good news is the transum is good, I guess being enclosed the way it is protects it, I cut some access holes in the splashwell a lot easier to get at the drain, bilge, and live well pump, I might install a live well in the rear passenger side, also will be easier access to the batteries. IMG_5994.jpgIMG_5999.jpgIMG_5997.jpgIMG_5998.jpg
