198? Force outboard motor - 85 hp
dfb1935
Motor won't start. Jumped starting solenoid out and starter will begin to "crank". Changed solenoid out - no help. Need electrical wiring schematic. Thanks.
moderator1
Re: 198? Force outboard motor - 85 hp
Moving to Chrysler/Force Troubles.
The Marine Doctor
Look for 12 volts at the yellow wire on the soleniod. If none is found trace the yellow to the neutral safety switch and test for voltage there. If none is found..short the ign switch...red and yellow together.<br /><br />TMD
