1980 140horse Mercruiser running prob.
JPol65
I have a 1980 EBKO with a 140 I/O. I just changed it from points to electronic ignition. It no longer idles unless you give it a little throttle. I was wondering do I have to have it timed or what? :confused: It was running fine with the points, I just got tired of changing the points every year.
Don S
Re: 1980 140horse Mercruiser running prob.
Yes you have to have it timed, you also need to readjust the carb mixture and reset the idle speed..
whywhyzed
Banned
yes, I had to reset the timing after installing my pertronix kit...
JPol65
Thanks, I guess they never tell you what you have to do, until you purchase something
JPol65
Is this something I can do myself, or do I need to leave it to the professionals?
Don S
Come on, none of us know if you have the knowledge or ability to set the timeing, you have to ask your self that.<br />Do you have a timing light and know how to use it? Do you know what 6° BTDC at 650 to 700 rpm means, Do you understand checking the advance timing? How about adjusting the idle mixture, and rpm?
JPol65
Yes I have a timing light, and yes I know how to use it. I do know what BTDC(before top dead center of the #1 cylinder is, at 650 to 700 revs. per min. means. yes, yes and yes, I was just wondering should I leave to the pros. or not, a simple yes or no will do.
As Don stated,..........That's an Unanswerable Question.............<br /><br /> IF you Know what you're Doing,......... Go For It........<br /><br /> IF you have Doubts,.......... Call a Tech.........<br />
It's My Guess ,........<br />That IF you Thought you could just drop in that module,+ Go Boating, without Any Tuning, or other Set-Up,+ Adjustments,.................<br /><br />You Probably otta Call a Tech............
JPol65
Thanks , Bondo, we'll let ya know how it goes.
DHPMARINE
Being a "tech",and not knowing what electronic ignition he installed,where should I set his timing when he comes to me ?Sounds like the "dwell" changed quite a bit if it no longer will idle as before.<br /><br />DHP
