Happyfingers
Thread starter- Joined
- Apr 12, 2010
- 29
hello
i have just replaced the impeller and thermostat
brand new gasket for the cooling plate
cleaned out all the water passages with compressed air
put it all back together and start her up in a tub
what should i be seeing ?
the pee hole is definately peeing (but the water doesnt seem to get warm)
but i could not see any water coming out the exhaust holes at the bottom (should i be)
the engine ran quite happily for a good 10 mins
i touched the cooling plate but it was too hot to touch for more than a second or so (after about 10 mins run time)
im not exactly sure if this is what i should be seeing
if there is supposed to be water coming out the exhaust holes on the leg then i can only guess that the thermostat isnt working (its brand new)
any ideas ???
any ideas ???
