Coloradolakeboy
Thread starter- Joined
- Jun 21, 2010
- 197
I live in Colorado and the elevation where I boat varies from 5000 ft to 9000 ft. Since the carb and fuel pump rebuilds and re-jetting for high altitude, I am only getting 3000 RPM and bogging under load (Tubers). Full Throttle RPM range 5300-5800. Once planed out and motor trimmed occasionally 5000 RPM . Idle is fine. Starts well, except on Ramp! Carbs and Fuel Pump rebuilt and new lines and bulb, Ignition test out good. Compression tested 120-125 with #6 at 115 at our 5000 ft. elevation. A local Mercury mechanic tested 15000 volts on plug wires and did the Link and Sync. He said the ignition was fine. I've got a 14.5 x 17 prop on it. Is this a fuel side problem or what? Thanks.
Rob
Edit: The tach was acting goofy last time out. Got Stuck at 5000 RPM.
Rob
