1980 25 hp johnson seahorse
stingertrey
Me and my buddy have been running this motor on a boat for sometime and were wondering what Other motors are compatable with this one for me to swap the carbs to pick up more hp? Thats all I need to do right is swap the carburetor right? are there any 30 or 35 hp carbs that would fit on this and work?
1946Zephyr
Re: 1980 25 hp johnson seahorse
I have actually seen other posts here where people have used 35hp carburation on their 25's to beef up the horsepower. I happen to own a 1986 model, myself. From 1977 on, they had the 33 cid displacement like the 35's
I would wait to see if someone chimes in here before you take my word as gospel. :cool:
rolmops
You can indeed do this.However what you increase is the fuel consumption and the RPMs.You will run your 25 horse at 6000 to 7000 rpm,which makes for a short life expectancy.
The other differences are in the gear ratio and the exhaust structure.
G DANE
The 20 compared to 25 has a carb with a limiter and a low compression head. ( in 1980 ) The difference up to 35 is mid-section and thru-hub exhaust, intake manifold and carbureator. Later on they all got thru-hub and main difference is then in intake manifold and carb. Changing carb on a 1980 will give you next to nothing.
stingertrey
So this isn't possible is what your telling me?
emckelvy
If your 25hp has the old-style lower unit which does not have flo-thru exhaust (exhausting thru the prop body) but rather a shear-pin type of drive with plastic nose cone on the end of the propshaft, held in place with a cotter key, it won't accomplish anything by putting a larger carb on it.
The models with flo-thru exhaust had extra breathing capability. Like having larger exhaust pipes on your car.
You could bolt a larger carb on your motor, but all it would do thru the pip-squeak old-style exhaust is make more noise and use more gas.
Later-model 20's & 25's with flo-thru exhaust were 'strangled' at the carb end by either a very small carb/manifold hole, or just a smaller-throated carb. These you can modify successfully and have a stronger-running motor.
If you do happen to have one like that it might work, however from the description/year it doesn't sound like it.
HTH..........ed
14ftgrumman
Easiest way to get more power out of a 25HP is to buy a 35 or 40.
Easier and less expensive in the long run, not to mention a lot more dependable.
jasper60103
I agree. I have the same motor. It's a good runner and simple to work on.
I may eventually upgrade to a 35, but plan to keep the 25 as a backup.
