1980 35 hp evinrude lost power
Bobdag
What do you mean by decarb? I took the carb off and rebuilt it thinking that was the issue.
Tim Frank
Check spark with a purpose-built tester...open gap to 7/16". Need a sharp, "snappy" blue spark.
If that is OK, move back to fuel system troubleshooting,
Check fuel pump output pressure with gauge.
Fed
When you replaced the fuel pump & lines you could have introduced some junk back into the carb if the work was done after the carb job.
The filter is before the fuel pump so you have to be extra careful doing anything after the filter.
Might be worth revisiting the carb.
Bobdag
The motor started acting up before the carb and fuel pump were done.
Bobdag
I bought a tester on my way home tonight. #1 only shoots a tiny spark. Like 1/16
#2 shoots a 1/2". So I'm thinking 2 coil packs are in my future!
jimmbo
Using a combustion chamber cleaner. Helps free up the piston rings to they are able to expand and contract as the piston moves in the bore. Always a good maintenance procedure
interalian
Swap the coils before you buy replacements. Could be something else.
Tim Frank
First, I'd only be worried about #1.... the 1/2" on #2 is more than the 7/16" that seems to be the accepted spec.
Second, as someone suggested, swap the "known-good" coil first...could must be at least $50- , and don't really fail as often as they get replaced.
Trouble shoot the circuit for number one, starting with the obvious...do a complete visual sweep, then make sure any connections are tight and corrosion-free.
Bobdag
Ok so I swapped the coils and ohmed them out also. It is a bad coil. Not the power pack.
Bobdag
Boat is fixed and running better than ever! Thanks for all the help everyone!
