1980 4.5 hp evinrude lean/rich
pointblank1000
sO, EXACTLY WHAT DOES THE "LEAN/RICH" KNOB DO? LEAN= LESS OIL.....RICH= MORE OIL???
hidef
Re: 1980 4.5 hp evinrude lean/rich
Lean equals less fuel mixture to air. Rich equals more fuel mixture to air. Your low speed jet should be 1 1/4 to 1 1/2 turns out from bottom. You want it so the engine will idle smoothly. I hope you are premixing your fuel at 50:1 using TC-W3 two stroke oil.
pocon1
I have a 4.5 evinrude mod: CSS E5R battery charger does the charger delivers 6 amp / Hr?.
You must have a charge controller or voltage?
Thanks for the reply
