1980 50 hp Johnson tempature sensor replacement
Quick3201
I bought the manual, can't find a good description of how to remove the temp. sensor without destroying it. It looks like it is just pushed into thr head. How does it come out?
Thanks in advance!!
F_R
Honorary Supreme Mariner
It is pushed into the head and held there by the cover plate. It is rubber and generally sticks in the hole, so you can't really get ahold of it except by pulling on the wires, which usually destroys it. Word from here: Leave it alone. Yeah, yeah, I know, you probably are wanting to test it. An exercise in futility. So you test it and find it works today......does that mean it will work tomorrow?? Will your car start tomorrow?
Quick3201
Thanks, found out it works, short at control box. Thanks,
